I've never run a steering damper, and I now run later NF5 forks (and an HRC shock) and the handling is wonderful. If your rear shock is buggered/on the way out then that can cause it to slap. Just because the front's wobbly, don't just assume it's the forks. I wouldn't advocate over-tightening the head bearings either. It's not a cure.
It's strange, as the MC21 has a shorter wheelbase than the MC18, and significantly shorter wheelbase than the RGV (by about 40mm
mixalisen wrote:
Mine MC28 doesn't slap at all... And that's because it hasn't the power to do it...!!!!![]()
(at the present...!!!)
The problem there Michael, is once you have the power, you have that rubber swingarm to contend with!
