 Topic: Anyone read japanese?
nsrdownunder
nsrdownunder » Sun Nov 08, 2009 10:24 am
To check oil injection pre-mix some fuel take of oil injection pipes block them of put hoses on oil injector into container run bike ,you can go for ride but i just turn oil injector on by hand and see if oil is pumping.
The specs on here run same plugs front and rear.
was the cylinder heat seized or seized from lack of oil somtimes you can tell by the look of them
