 Topic: fuel petcock stuck, is there a trick
Blue Smoke
Blue Smoke » Tue Apr 05, 2005 5:26 am
When my bike had been sitting for a while, the fuel broke down and jammed the tap.
Sounds like this might be whats causing your problem. I drained the fuel and removed the tap from the tank and gave it a good clean out.
Shake the tank and see if you can hear anything moving around inside the tank like sand Confused
