Sorry yes, needles and emulsion tubes are longer. I should have taken some photos.
And SJs were shorter.
So now I've got the shorter pair but still the long needles.
How do you get needles out? When I open the top of the carb it's just a metal tab or something in there.
Needle doesn't foul so maybe it's a stock needle moved down (if they can be) or a HRC needle that's up a bit.
Still a bit confused by the whole thing.
If you have longer emulsion tubes should you set your float differently?
