My name is John and I am from Greece. First of all I would like to congratulate you for a well organised site!
I recently owned a NSR 250 from a friend who had the bike "sleeping" for about 8 years....
As you will see from the pictures, its condition is pretty good if you overlook the dust and the spider nests.
What I want to ask you is what I must see/check/change in order to make it running again. The bike had no problem until the last day it was parked so I guess no mechanical problem exists.
Besides a good outside cleaning I intend to clean the carb and check for leakings. A friend told me that because of the years, the timing of the engine must be set again, is that true?
And finally (for now) could someone tell what year and model is the bike so I can look at the correct on-line manual(if you can see it from the pics). It says MC18 as you can see. Any other pictures, info needed from the bike I can gladly post!
Thank you in advance!
