So i thought fkit, ive changed plugs, rebuilt the carby, pulled all the fairings off so i could jiggle all the wires, cant make it stall. Time to check the simple things...
Took the kill switch off to examine the connections , was just about to disassemble and noticed the 2 wires coming off the brake caliper. Found a nice little split facing the stanchion, which had a puncture right where the split was resting.
So turns out the brake light switch wires were the cause of the problem. Shorting out on the stanchion killing the electric system
