 Topic: Still not running right..
SHINEYCUEBALL
SHINEYCUEBALL » Fri Mar 19, 2010 5:08 pm
Just a side thought.... I presume you are confident that the ignition is as it should be? If you have serviced the bike recently with new fuel/air filters, checked float heights/condition and nothing is obstructing the inlet then it should pull standard jetting. Weak ignition at higher revs can seem like richness. I`d make sure your ignition was sound before I played with the fuelling....
