 Topic: D piston in larger barrel - what rings do I use?
Neal
Neal » Sat Mar 20, 2010 8:38 pm
You don't want the piston too loose as it will rattle in the bore and break the piston skirts . Make sure the bike is at running temp before you speed off . I have never measured the piston to bore clearance of a worn piston to compare results .
