cheap price that but how will the mild steel compare to the stainless as regards to rusting?
are they coated?
i have always liked the gp style but...
do the gp style fit on with no mods to the bodywork?
also do the gp pipes give less performance than standard front pipes?
The chambers are designed to give clearance to the swing arm and stock footpeg hangers as well as work with our Tyga Performance step kit STAA-0002. The stock bodywork does not need to be cut, unlike when used with some other manufacturer's chambers. (though repositioning of rear lower cowling down by 25mm is recommended)
pipes come clear coated for protection
