craigsutton wrote:
...if you've been trying to turn the nut the wrong way it might be on super tight now.
If you've been trying to unscrew the nut the wrong way (it's a left hand thread, as Craig pointed out), then from what you are describing you have most likely stripped the thread off the end of the RC Valve shaft. They tend to strip before the end shears off!
