Awesome
Thanks Andy.
We pulled them down for a clean, and were unsure, so we reassembled them without modifing the float, and now one is overflowing.
I noticed that there is fuel mist coming back out the of carb that is overflowing.
The engine starts and runs ok. Its a little flat off idle, but i need to adj the air screw, and put the air box back on. The pulsing i can feel with my hand at the carbie mouth is the same on both carbs, just one has fuel mist once you shut the throtle.
Is this related to the float being set incorrectly ?
I was just blipping the throttle from idle to about 4k. It did not seem to have the mist on acceleration, only on decel.
