 Topic: eletrical problem
Dave Ett » Fri May 21, 2010 9:22 pm
I suspect the wiring loom is chaffed through and shorting out on the frame somewhere. I'd start by looking at the left hand side where the loom passes tight to the frame as it goes forward to the clocks.
Rather than keep throwing fuses in, make up a light bulb with a couple of short wires to put into that fuse holder, that way you'll know you've found the fault when the light goes out. Wink
