 Topic: R5k running issues
drunkn munky
R5k running issues
drunkn munky » Mon Jun 21, 2010 2:31 pm
Im having problems with the revs dropping off slowly, when stopping or just by pulling the clutch in the revs drop slowly to 3k then stay there for a few seconds before dropping to tick over, this happens all the time and is not just intermitent. Im guessing an airleak somewhere but i thought a air leak would make the revs more eractic???
Bike is stock apart from the wire splice, airbox is also stock for the time being. When starting from cold the engine revs will rise to 5-6k without using the choke and then after 30 secs drop very slowly to tick over, i cant seem to find any info on weather this is correct or not but im guessing not.
Im prepared to remove and strip the carbs but just looking for pointers as to what may be causing the problem. Other than this the bike runs great, a little rough down low sometimes but sweet as a nut once it gets going and pulls strong upto the redline.
