 Topic: WANTED MC21 front wheel
cgallant
cgallant » Sun Aug 22, 2010 4:00 pm
OKay,
got the front rim pulled and cleaned up a little. Removed the disc's, but didn't make it to the shop yesterday to pull the tire (will remove this prior to shipping).
Here are some pics. Rim is straigh, with a small section on one side of a little curb rash (rim/lip are still straight). Would recommend replacing bearings/seals as they are an unknown to me. I have always had luck going to any bearing supply store with the part numbers found on the side of the bearings. No need to order from Honda and overpay and wait for ever to get them. Seals are standard honda seals.
Shot me your email address and I can send you higher res pics if you want them.
Charles Gallant
