 Topic: paint results
Wrathfultalon
Wrathfultalon » Sun Sep 05, 2010 1:16 am
so let me line this out and you guys let me know what you think
1. putty and resin the panels, followed by sanding and cleaning off dust
2. filler coat 3 layers (all they got here is primer) wet sand and clean this again, 600- 800 grit.
3 sealer coat 3 layers(dont have so would use thin clear coat) wet sand 600- 800 grit
4 base coat 3 layers wet sand with 1000 grit, clean off
5. Clear coat. this is a thin coating several coatings, wet sand 1000
6 thicker clear coat 3 layers, wet sand 1500 to 2000 and rubbing compound or perform a final coat.
this is what i am getting from input correct me if i am wrong. product availability is very low here so keep that in mind.
