http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=ja&tl=en&u=http://mc28tsuruta.web.fc2.com/
Try that.
It's not rocket science though... look at the parts manual so see how it all goes together and you'll soon realise how easy it is to disassemble and service.
Once the RC Valve backplate is off (the part the cable adjusters screw into) the RC Valve shaft just pulls out (complete with E-clip and seal). If it's all kept clean and serviced properly, you can put the shaft out by hand!
If you're doing it without removing the barrel, turn the crank to TDC as it makes it easier to manipulate the Valve flaps into place.
