Er no!
Well, that's the desperate way to get moving if you're stuck somewhere, but your tranny won't last long!
Try putting the bike in gear with the engine off, pulling in the clutch and pushing it. Any better? Sometimes the spinning engine makes it worse.
Bit obvious, but have you checked the free play on the cable? If that's not properly adjusted, it'll not disengage. And is it free and smooth? Maybe old and gunked up.
Other than that I can only advise getting the revs up good and high as you put it into gear - gently. try paddling the bike forward as you do this to reduce the snatch on the chain. Once you're off you may find it eases up after a while once the motor is hot and oil is lubing everything better.
