 Topic: float problem?
NSR-LOVER
NSR-LOVER » Mon Jan 10, 2011 5:34 pm
Ive tried everything! it took me 5 minutes to fit needles, tubes, jets and over an hour with a friend trying to set the floats with lots of pictures from the netbook... even without the needle valves the floats are going out nearly 20mm at the 90 degree measurement! when i turn the carb as to level the floats with the floor then they go inside near the 13mm measurement but this is not 90 degree thats why i think maybe they are bented. not the tab all the float!
