Primary drive gear
Ends of the two crankshafts (broken one first)
Why are they different? They both have the same bearing and seals, they both fit into the cases perfectly, both primary drive gears fit on the end of the crank and the taper on the flywheel ends are the same as well. I am worried that the smaller drive gear wont engage properly on the clutch gear. Can I use this spare crank or do I get the original one rebuilt, assuming that the pins are all ok? Off to go clean more parts. Thanks heaps for any help, appreciate it!
