 Topic: dry clutch conversion
StephenRC45 » Thu Feb 24, 2011 8:38 pm
I use the Mr Matt way and have either the Honda tool (which is a couple of teeth of a gear on a pin) or a lump of aluminium between the teeth.
The crank primary gear should just pull off but if not a thin two legged puller does the job.
