 Topic: front cylinder running cool
nsrdownunder
nsrdownunder » Sat Mar 12, 2011 1:02 am
check out this thread http://www.nsr250.net/forums/viewtopic.php?t=2220&highlight=pressure+test . Another way to check is to take the carbs of fill the top cylinder crankcase with petrol and leave for a while(overnight) and see if it leaks into the other side not as good as pressure test but should will tell you if seals leak a bit
