 Topic: New Member Here :) Australia
nxrsr20
nxrsr20 » Thu Mar 17, 2011 4:42 am
they are your transistors that control your RC valves.
First thing I would do is service your RC valves and then reset cable tension.
I would then check that your servo motor is working correctly. Check motor hasn't jammed up and cycles through full range of movement.
After all this is setup correctly then I would plug in a fresh PGM and pray Shocked
