watfordhorn wrote:Good news, sound like your getting there! Is the wiring all correct to the tps?
Mc28's don't have a headlight switch. They always cone on with the first kick, then they are on until you pull the card out to turn it off.
TPS is wired up correctly. I took it all apart yesterday and cleaned ever last bit.
I've read somewhere about calibrating the TPS but I don't see how. I took it all off yesterday and there is a rotating peice on the carb with washer and slotted peice of plastic, on the inside of the black socket (with the wires that connect to the bracket above) is another rotating peice and they fit snuggly together. Where are you supposed to make adjustments/calibration?
Going to spend all day tomorrow and Saturday setting up this beast, loving the learning curve!
