joeking78 wrote:I noticed that the front cylinder RC valve is half open whilst the rear cylinder is fully open (fully recessed). The strange thing is that both RC valve pulleys are lined up with the indicator on the pulley back plate.
You'll figure it out.
Remove cables from the pulley on the barrel.
Remove pulley.
You'll suss it by that stage.
joeking78 wrote:Also, how smoothly/freely should the RC valve pulleys operate?
With the pulley removed, the RC valves should be easy enough to move by hand using just the valve shaft. If not they'll need cleaning.
Once the illignment problem is solved and the valves are clean, adjust the cables as per Directions <<<Click
