the clocks read 19000k kms.
the bike has had a full engine rebuild in the past i can see that because the gaskets look clean.
i have looked up the exhaust ports and the piston look clean and the bore looks good, but the top of each piston is a light brown colour not sure if this is normal or not?.
i thought i had leaking crank seals but it was only the rear shock leaking and was covering the inside of the fairing in oil and some found its way onto the engine.
i have replaced the rear shock with another used oem mc18 shock i have from a donor bike.
i also noticed that the lower cylinder exhaust gasket was leaking i have replaced both gaskets and the bike runs much better now you can feel the front trying to lift when the powervalves kick in in first gear
