 Topic: Idle screw broken?
joeking78
joeking78 » Sat Apr 30, 2011 6:22 pm
Well that was a midnight mission!
Took a torch out, tank off, carbs off and sure enough the idle screw was not attached. Found a little spring, washer and small bracket so put it all back together.
It started but after a few seconds the revs started to climb, when it got near 5k I cut the engine. Will have to investigate this further tomorrrow as I tried to start it again and it wouldn't have it.
