 Topic: Rectifier problems MC28
fstnsr
fstnsr » Sun May 08, 2011 1:58 am
Hermit wrote:Hey bro, John is saying that the black plastic 'undertray' that comes with the Tyga kit is serving only to keep heat inside the fairing which is adding to your problem. If you chuck it in the bin then air will flow through the tail fairing better and help to cool your reg/rec.
So he's recommending that you make up a more effective heat sink to mount your reg/rec to AND get rid of the undertray to improve cooling airflow.
Never buy parts from inside NZ mate. Not unless you enjoy a good raping anyway. Unless they're from econhonda in Te Aroha:
http://www.econohonda.co.nz/
I think i got my spare reg/rec from Tyga as part of a larger shipment of bits and pieces - as John says: the part is common to many Hondas and the one i have now has cooling fins cast into its body as an added bonus. Even if you buy just the reg/rec from over seas then add shipping and gst you'll still save yourself a fortune on what the NZ wholesaler will charge you. Because they are dirty, get rich quick c**ts.
As for what's causing the blow outs i can't help there mate, sorry.
Cheers Hermit. I dont know how I miss read the post so bad. Yes have a piece of heat sink I can use to cool it down and will get rid of the plastic cover.
The Part number for the mc 28 reg/rec is 31600-MV4-000 but Eco doesnt have any exact part in stock. Does anyone have any other Honda reg/rect part numbers with work?
94 mc28 SE
