 Topic: Compression Ratio's
MAINE 2 STROKER
fuel injection not likely
MAINE 2 STROKER » Wed May 04, 2005 8:42 pm
dont think the technology is up to par yet
just goin by memory here, but i was running some numbers way back in high school one day on a KX250, and i belive that at 10000 rpm the piston was going up and down 166 times a second.
thats 166 required squirts of fuel per second..
maybe if you have 4 injectors per cyl that would be about 40 per second per injector. not sure of the current rate of injection, but im guessing there is no way to do it with one, or even 2 injectors with current technology.
with a 4 Smoke, you can be revving to 13000, and only need injection at half that rate since it only fires every other time the piston is at TDC. I think the fuel injected 4 Smokes currently use about 2 injectors per cyclinder.
Wasnt that Bimota 500 Vdue supposed to be injected
dont recall that worked out too well
changed to carbs and still didnt sell them..??
Koren
2 Strokes and I'm Off Rolling Eyes
