 Topic: Power valve problem
Chester362
Chester362 » Sat May 28, 2011 4:54 pm
Turn the servo to the high position with the ignition off. See if it moves when the ignition's switched back on.
As John says, does the servo start to move again when you hit around 8000 to 9000rpm when blipping the throttle in neutral?
