On the bottle it will say something like "pre-mix", "injector" or "suitable for pre-mix and injector systems". If in any doubt, just ask the supplier. The labels are often colour coded. Silkolene used to be purple for Pro2 (synthetic injector, years ago when I first used it!), orange for Comp2 (semi synthetic suitable for injector & pre-mix), and yellow for pre-mix. I don't know how it is now though... read the lables, and ask someone!
Of the list you give, personally I would chose the Silkolene and then Motul. I myself only use Rockoil or Castrol. You can mix synthetics (mix brands) if you want, but I don't see why you'd need to, living next to the shop! Just pick one, and stick with it best you can.
Top tip:
Top the oil bottle back up after EVERY ride, and that will ensure you (virtually) never run low and have to go hunting for synthetic!
