I am fitting a replacement clutch cover with new waterpump, it was only untill I began to sort where each bolt goes that I realised the cover is slightly differnt!
Two of the mounting points require longer bolts to fit and the water pump is much bigger.
I hope you can see from the pictures what is differnt.
I am not worryed about using this cover as it is better from a performance aspect but I dont know where to get the two longer bolts required to fit.
Can any one tell me what series the cover is from, my old one is a 250R 4jSP
Cheers, Ash
