Are you sure that the bike has to be started to see if the power-valves work?
Cause I read this here about setting them:
With the kill switch set to the run position, turn the ignition on with the key/card. Allow the Valve to cycle to the start setting.
Doesnt say that the bike has to be started, and it doesnt make sence to me either- I believe it should be like on RDs operate after the ignition key is turned.
CAN somebody please tell me if the power-valves turn and set with the ignition turned on, or the bike needs to be started? (MC 21)
Thanks in advance
