 Topic: Should rc valve move?
tom tom
tom tom » Thu Jun 23, 2011 9:16 pm
Hi all I've read on the site about the rc valve moving through a cycle when ignition is switched on, but also read that it doesn't, so to clear it up for me which is it? When I turn the key my rc valves don't move, if I start it and rev then they move, if I turn ignition off and turn valve by had then turn ignition on then the valves move, but on odd occasion when I turn ignition on they move slighty does this sound right? I've used search but if you type rc valve you get about 10,00000 hits
Can someone put my mind at rest?
