 Topic: more power valve faults
elmo
elmo » Sun Jul 03, 2011 2:21 am
so after going over the cables twice i went to the electrics found the voltage to the servo would go from 12v to 6v every now and then and i could make it worse buy shaking the bike wiring so must have a short some were right?
so i check all the wiring no faults then i noticed it was doing the same thing with volt meter direct to battery removed battery and found it must have a short in one cell or something maybe one of the posts is corroded were it comes through the top case not sure but first time i seen one do this.
also when id pull up at lights with a blinker on it would cut out sometimes "thats fixed now to"
cheers for all the idea's
