Whent to the dyno today with these results.
Dotted line - Singe
Solid line - Double
Same bike, same setup except changed flywheel from lightened to total loss.
O and worth mentioning is a 28 !
EDIT : Ok so to show a closer comparison I went to the dyno again with these results..
1st Graph : Dotted line(Run13) - Single ring pistons with lightened flywheel.
: Solid lind(Run18) - Double ring pistons with lightened flywheel.
2nd Graph : Dotted line(Run19) - Double ring pistons with lightened flywheel.
: Solid line(Run20) - Double ring pistons with total loss rotor.
Reason for the small difference between run 18 and 20 is because I changed one jet size.
