I have a MC28 subframe that I do not need and you can have it for free ...though I believe the postage costs would be a little bit on the high side and I'm pretty sure that the mc16 tail will no longer fit. Check that it bolts on your frame and if you don't have any other alternatives, let me know.
By the way, you might want to consider fixing your own. Mild steel is not that hard to work on...
2t-racelab.com
