 Topic: Is restriction bad??
Harryredchow
Harryredchow » Wed Aug 10, 2011 6:19 am
The splice takes 2 minutes. Why not ride to your local rolling road, get a run done without the splice and one after and compare the air fuel ratios of the two runs. It will most likely be no different. I did just the splice and the fueling is still spot on. If I did the airbox mod too I would get the fueling checked again.
