 Topic: Problems with nsr250 mc21 help.
Dave Ett » Mon Aug 15, 2011 9:33 pm
Is the bike completely standard or modified in any way?
That kind of behaviour sounds like an electrical fault to me.
When did you last check that the power valves rotated freely, and weren't sticking through carbon build up?
Check the throttle position sensor is firmly screwed to the right side of the carbs, and get a multimeter on it to check the resistance changes smoothly as you slowly rotate the throttle.
Check the plugs to the PGM (in the seat hump) are firmly attached.
Could also be an earth fault, so check the battery cables, and earthing lead to the frame are making good contact.
