 Topic: Problems with nsr250 mc21 help.
shmokica
shmokica » Sat Aug 20, 2011 12:30 am
Check the voltage as the revs increase, ie slowly increase the revs, the voltage output should stabilise around 14.5V. 14.4V seems high for idle. The reason I ask is if the voltage regulator is faulty, the voltage will just continue to increase. This increased voltage level will in turn alter the way that the electrical circuits operate, ie timing, coils etc.
