 Topic: Downshift issues
NSAAGGHHH
Downshift issues
NSAAGGHHH » Sun Sep 11, 2011 7:47 am
Gday guys, hope you can shed some light on another of my bikes strange personality traits,
its now decided it doesnt like downshifting into the lower gears when its warmed up to normal runnings temps. Its an intermittent issue but when it does shift its very smooth to the point untill the clutch is released you dont know if its changed or not.
When it doesnt shift, ive tried holding the clutch in again and very concientiosly pressing the gear shifter and it has no effect. Sometimes i can eventually get it to go, but its hit and miss.
I had the same reverse issue a while back with it not wanting to upshift under hard acceleration.
Ive changed the gearbox oil recently and the level is good (took 700ml) Upshifting no problems.
Side question, i need new exhaust gaskets - they are over $30 each here for genuine or ive seen an english auctioner selling some cheapies, for 3quid each or 10 for 12quid. Is a gasket a gasket? or is there somewhere else someone can share with me where to buy them?
