When I turn on the key, neutral and side stand light bulb turn on normally and when I switch the run on the oil light bulb doesn't turn on.
I Know that in other NSR MC21's SP this oil bulb turns on until the engine is turned on and then it switches off.
I have checked that the bulb is good because when my oil level is low the bulb switches on normally so the problem seems to be only the initial test!
