 Topic: Disks Wanted
shmokica
shmokica » Sat Sep 24, 2011 10:34 pm
Have you tried WD40 and rotated the bobbins to see if it's just stuck? A bolt through the bobbins will allow you to rotate them. I thought my disks were warped, but after doing this they were fine. Note: Should be obvious but don't put the WD40 on the main part of the disk, and you'll need to clean the excess off before reuse.
