 Topic: O ring 300 heads
Matt@TYGA » Sun Oct 16, 2011 3:12 am
The VHM heads are designed allow or restrict flow around the outside of the insert without letting the water escape out through the outlet without doing it's job. If you just throw a std head on without a gasket the water will not adequately cool the front side of the combustion chamber.
