 Topic: mc28 Popping out of gear . . .
ate51
ate51 » Wed Oct 26, 2011 1:52 am
Greetings,
Had my mc28 on the track and it has started to occasionally pop out of gear and then goes back in almost immediately without me doing anything with the clutch or shifter. Always wide open on a straightaway in a higher gear, relatively low rpm, usually around 9-10k so a lot of load on the trans. It's like what would happen if I pulled the clutch in quickly and immediately let it go. Quite abrupt. Occasionally it will actually pop out of gear completely in a false neutral but I attributed that to not getting a fully positive shift with my foot. Gearbox oil is fresh. Any advice on what it might be and is there enough risk of destroying the gearbox I should quit riding it? Thanks in advance!
- Brian
