 Topic: RC Valve adjustment
nobby62
nobby62 » Sat Nov 26, 2011 11:26 pm
Yeah, seems like a very simple procedure in the mag, (or your method) to find the max opening of the servo then adjust the valve to suit. The honda method involved disconnecting the tps.... how does this affect things, is it just so that a pre-set servo pulley position can be obtained... and then the valve adjusted to a ccrresponding pre-set position?..without having to make your own mark..?
