I just fully rebuild my nsr! Rebuild crank, new pistons new piston rings and many other!
My nsr is full stock with geniue parts! except the main jet. Jet sizes removed bu admin. Please read the forum rules.
I did 1000km and i test it and i wasnt happy so i done the wire splice in pgm and in gps.
My problem is when i have 5 gear at 10k rpm stops accelerate with 6 gear the same!
I check it in 1st  and second gear it goes 12k rpm in 4 gear accelerate good until 10k rpm and the power stops but it can go 12k if i keep the throttle full but it is pointless in 5 gear at 10k rpm it dyes like restricted
So what do you think i should check?
