Less surface area, so the piston absorbs less heat from the combustion, also there is less absorption of radiant heat from a shiny surface.
I wonder if it's worth smoothing the dome on cast pistons and polishing for a similar effect? So long as the piston isn't weakened, but you might have to remove a lot of material if the piston castings are rough.
