Leigh,
it does take some time to see oil coming through.
Especially if you haven't filled the oil hoses going to the carb manifolds with oil (I use a syringe to fill them up).
If I were you, I would remove the oil pump for a clean up and also check that the oil shaft is still in it's place...
2t-racelab.com
