Thanks for the reply.
I have removed the feed until oil is flowing properly, removed the shaft until oil is flowing and then removed the belles screw until oil is flowing - all as per the manual. Then run it for a good few minutes with no sign of any oil being pumped.
The oil hoses are not connected at the moment I was just hopin to see oil coming out of the actual pump. Maybe I should try connecting them as well.
