 Topic: which lights come on with ignition???
Bomber
Bomber » Sat Mar 31, 2012 5:18 pm
Hi,
Sorry for the bone questions but this is the first time since I've had the bike its had both an ignition switch and battery! I'm just checking out the electrics at the moment and having a few issues! The neutral light and oil light don't come on with the ignition switch set to on? Should they be on?? Yes the bike is in neutral, and the oil tank is empty at the minute.The neutral light doesn't come on if the connector to the neutral switch is grounded either and I would have thought the oil light should come on as a test function regardless of oil level??? All bulbs in the instrument cluster have been tested and are all ok. All the other instrument cluster bulbs illuminate, ie both turn / hi beam and back lighting so I doubt its the instrument cluster wiring.
I can't start the bike yet to see if that makes any difference as I'm a few days away from that milestone/headache!!
Any help would be thankfully received,
Paul
